C#.net大文件上传解决方案支持分片断点上传
2021年1月29日 22:1 本文热度 6427
HTML部分
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="index.aspx.cs" Inherits="up6.index" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head>
     <meta http-equiv="Content-Type" content="text/html; charset=gb2312" />
    <title>up6-多标签演示页面</title>
    <link href="js/up6.css" type="text/css" rel="Stylesheet" charset="gb2312"/>
    <script type="text/javascript" src="js/jquery-1.4.min.js"></script>
    <script type="text/javascript" src="js/json2.min.js" charset="utf-8"></script>
    <script type="text/javascript" src="js/up6.config.js" charset="utf-8"></script>
    <script type="text/javascript" src="js/up6.app.js" charset="utf-8"></script>
    <script type="text/javascript" src="js/up6.edge.js" charset="utf-8"></script>
    <script type="text/javascript" src="js/up6.file.js" charset="utf-8"></script>
    <script type="text/javascript" src="js/up6.folder.js" charset="utf-8"></script>
    <script type="text/javascript" src="js/up6.js" charset="utf-8"></script>
    <script language="javascript" type="text/javascript">
        var cbMgr = new HttpUploaderMgr();
        cbMgr.event.md5Complete = function (obj, md5) { /*alert(md5);*/ };
        cbMgr.event.fileComplete = function (obj) { /*alert(obj.fileSvr.pathSvr);*/ };
        cbMgr.event.queueComplete = function () { $(document.body).append("队列完成<br/>"); }
        cbMgr.event.addFdError = function (jv) { alert("本地路径不存在:" + jv.path); };
        cbMgr.event.scanComplete = function (obj) { /*alert(obj.folderSvr.pathLoc);*/ };
        cbMgr.Config["Cookie"] = 'ASP.NET_SessionId=<%=Session.SessionID%>';
        cbMgr.Config.Fields["uid"] = 0;
        $(function ()
            cbMgr.load_to("FilePanel");
            //上传指定文件
            $("#btnUpF").click(function () {
                var path = $("#filePath").val();
                cbMgr.app.addFile({ pathLoc: path });
            //上传指定目录
            $("#btnUpFd").click(function () {
                var path = $("#folderPath").val();
                cbMgr.app.addFolder({ pathLoc: path });
    </script>
</head>
<body>
    <p>up6多标签上传演示页面</p>
    <p><a href="db/clear.aspx" target="_blank">清空数据库</a></p>
    <p><a href="filemgr/index.aspx" target="_blank">文件管理器演示</a></p>
    <p><a href="index2.aspx" target="_blank">单面板演示</a></p>
    <p><a href="down2/index.htm" target="_blank">打开下载页面</a></p>
    <p><a href="index-single.htm" target="_blank">单文件上传演示</a></p>
    <p>
        文件路径:<input id="filePath" type="text" size="50" value="D:\\360safe-inst.exe" />&nbsp;
        <input id="btnUpF" type="button" value="上传本地文件" />
    </p>
    <p>
        目录路径:<input id="folderPath" type="text" size="50" value="C:\\Users\\Administrator\\Desktop\\test" />&nbsp;
        <input id="btnUpFd" type="button" value="上传本地目录" />
    </p>
     <div id="FilePanel"></div>
    <div id="msg"></div>
</body>
</html>
代码部分
using  System;
using  System.Collections;
using  System.ComponentModel;
using  System.Data;
using  System.Drawing;
using  System.Web;
using  System.Web.SessionState;
using  System.Web.UI;
using  System.Web.UI.WebControls;
using  System.Web.UI.HtmlControls;
namespace  WebPortal
           ///  <summary>
           ///  UpLoad  的摘要说明。
           ///  实现多文件上传
           ///  </summary>
           public  class  Upload  :  System.Web.UI.Page
                       protected  System.Web.UI.WebControls.Button  UploadButton;
                       protected  System.Web.UI.WebControls.Label  strStatus;
                       private  void  Page_Load(object  sender,  System.EventArgs  e)
                                   ///  在此处放置用户代码以初始化页面
                                   if  (this.IsPostBack)  this.SaveImages();
                       private  Boolean  SaveImages()
                                   ///'遍历File表单元素
                                   HttpFileCollection  files    =  HttpContext.Current.Request.Files;
                                   ///  '状态信息
                                   System.Text.StringBuilder  strMsg  =  new  System.Text.StringBuilder();
                                   strMsg.Append("上传的文件分别是:<hr  color=red>");
                                   try
                                               for(int  iFile  =  0;  iFile  <  files.Count;  iFile++)
                                                           ///'检查文件扩展名字
                                                           HttpPostedFile  postedFile  =  files[iFile];
                                                           string  fileName,  fileExtension;
                                                           fileName  =  System.IO.Path.GetFileName(postedFile.FileName);
                                                           if  (fileName  !=  "")
        fileExtension  =  System.IO.Path.GetExtension(fileName);
        strMsg.Append("上传的文件类型:"  +  postedFile.ContentType.ToString()  +  "<br>");
        strMsg.Append("客户端文件地址:"  +  postedFile.FileName  +  "<br>");
        strMsg.Append("上传文件的文件名:"  +  fileName  +  "<br>");
        strMsg.Append("上传文件的扩展名:"  +  fileExtension  +  "<br><hr>");
        ///'可根据扩展名字的不同保存到不同的文件夹
        ///注意:可能要修改你的文件夹的匿名写入权限。
        postedFile.SaveAs(System.Web.HttpContext.Current.Request.MapPath("images/")  +  fileName);
                                               strStatus.Text  =  strMsg.ToString();
                                               return  true;
                                   catch(System.Exception  Ex)
                                               strStatus.Text  =  Ex.Message;
                                               return  false;
                       #region  Web  窗体设计器生成的代码
                       override  protected  void  OnInit(EventArgs  e)
                                   //  CODEGEN:  该调用是  ASP.NET  Web  窗体设计器所必需的。
                                   InitializeComponent();
                                   base.OnInit(e);
                       ///  <summary>
                       ///  设计器支持所需的方法  -  不要使用代码编辑器修改
                       ///  此方法的内容。
                       ///  </summary>
                       private  void  InitializeComponent()
                                   this.ID  =  "Upload";
                                   this.Load  +=  new  System.EventHandler(this.Page_Load);
                       #endregion
选择文件夹
js部分
后端代码逻辑大部分是相同的,目前能够支持MySQL,Oracle,SQL。在使用前需要配置一下数据库,可以参考我写的这篇文章:http://blog.ncmem.com/wordpress/2019/08/07/java超大文件上传与下载/
该文章在 2021/1/29 22:02:20 编辑过
